Prośba o rozkodowanie numeru VIN
Poproszę o rozkodowanie W0L0AHL3572084362
Model A04 ASTRA-H
Model Code 0TN35
Made 04.12.2006
Type body L35
Motor Z13DTH
The engine number 1659784
Options
EXTERIOR PAINT,SEE MODEL CATALOGUE FOREWORD PAINT CHART
COVER,FLOOR INNER,STANDARD
INTERIOR-BLACK
BODY INTERIOR TRIM-BLACK
DOOR PANEL TRIM,BLACK
FRONT BUCKET SEAT
FRONT SEAT,DRIVER,MANUAL ADJUSTING
HEAD RESTRAINT,REAR,CLOTH,TWO
FOR DRIVER,PASSENGER AND SIDE AIR BAG
HEAD RESTRAINT,REAR,CLOTH,CENTER
COVER,ASSY.,LUGGAGE
MOULDING DOOR INTERIOR,SILVER
INSTRUMENT PANEL MOULDING,SILVER
AIR CONDITIONING
FOR POLAND
HANDLE,ASSY.,OUTSIDE
MIRROR,ELECTRIC,RH-LH
MIRROR,ASSY
HOUSING
ASHTRAY AND CIGARETTE LIGHTER (SMOKERS PACK)
INSTRUMENT CLUSTER,BLACK,BLACK RINGS WITH SILVER TOP
ENJOY
COVER
KEY
AXLE RATIO 3.72
5 BOLT WHEEL FIXING
ABS
ALTERNATOR,100AMP
HEATER DUCT,REAR PASSENGER 2ND POSITION
ENGINE DIESEL, 4 CYL, 1.3 L4, DI DOHC, TURBO-HIGH
LEFT HAND DRIVE
USED WITH MANUAL TRANSMISSION
M20 MANUAL TRANSMISSION
STEERING WHEEL,THREE SPOKES
EQUIPMENT,EUROPEAN UNION
EMISSION,EEC 05
LOCAL GM OF EUROPE OHA
TRIM CLOTH, TABITA/ELBA
WHEEL,ROAD,STEEL,61/2JX16
TYRES,205/55 R 16-91H
FOR FULL SIZE SPARE WHEEL
TRIM PANEL,INNER,TABITA
BATTERY,60AH
GRILLE RADIATOR,BLACK,WITH CHROME BAR
FRAME,RADIO
RADIO EQUIPMENT COOLING SYSTEM
TRIPLE INFO LCD - DATE/TIME/TEMPERATURE
RADIO CONTROL SWITCH
SPEAKER,6
CARRIER,LUGGAGE,ROOF,POWDER COATED
LUGGAGE CARRIER CLEAR ROOF,BLACK
PROTECTION WAX
ISOLATOR BATTERY
FOR STEERING WHEEL RADIO OPERATION
EQUIPMENT RECEIVING UNIT,RADIO
SENSOR,RESTRAINT SYSTEM,LH
https://forum.opel24.com/topic/72789-pro%C5%9Bba-o-rozkodowanie-numeru-vin/page/50/#findComment-506215
  • Odpowiedzi 1,3 tys.
Jeszcze taki nr jak by można było po polsku, bo translator straszne głupoty tłumaczy.
W0L0AHL3592008946 Dzięki.
W0L:General Motors
0:Pojazd Nie Specjalny
A:Astra Platform H:2004 Platform Generation
L35:Estate
9:2009
2:Bochum
008946:SERIAL NUMBER
Numer silnika:1852979
Kod GM*Drive:TABR
Data produkcji: 19.08.2008
REG: DS089AA
18X = KOLOR WYKOŃCZENIA SIEDZENIA - CIEMNY WĘGIEL DRZEWNY2AU = FARBA ZEWNĘTRZNA,PATRZ TABELA FARB W PRZEDMOWIE DO KATALOGU MODELU2J1 = POKRYCIE,WNĘTRZE PODŁOGI,STANDARDOWE80I = WNĘTRZE-CZARNY80Y = WYKOŃCZENIE PŁATU DRZWI,CZARNYA51 = PRZEDNIE SIEDZENIE KUBEŁKOWEAH3 = SIEDZENIE PRZEDNIE,KIEROWCY,REGULACJA RĘCZNAAJ0 = ZAGŁÓWEK,TYLNY,TKANINA,DWAAJT = DOTYCZY WARUNKÓW MONTAŻU SIATKI ZABEZPIECZAJĄCEJAY0 = PODUSZKA POWIETRZNA,DACH,PRZÓDB75 = POKRYCIE BAGAŻY,ZESP.B86 = KOLOR LISTWY BOKU NADWOZIABNS = LISTWA WEWN. DRZWI, SATYNOWY KAMIEŃBPI = LISTWA TABL. ROZDZIELCZEJ,SATYNOWY KAMIEŃC60 = KLIMATYZACJAC95 = ŚWIATŁO,SUFITOWE,ZESP.,Z PODWÓJNĄ LAMPKĄ DO CZYTANIACT6 = DLA WŁOCHD75 = KLAMKA,ZESP.,ZEWNĘTRZNADDG = LUSTERKO,ELEKTRYCZNE,PRAWE-LEWEDDU = LUSTERKO,ZESP.DP6 = OBUDOWADT4 = POPIELNICZKA I ZAPALNICZKA (PAKIET DLA PALĄCYCH)DVA = ZESTAW WSKAŹNIKÓW,CZARNY,PIERŚCIENIE CZARNE ZE SREBRNYM WIERZCHOŁKIEME4Q = ENJOYE94 = POKRYWAECA = KLUCZYKFX3 = PROGRAM STATECZNOŚCI ELEKTRONICZNEJFXB = PRZEŁOŻENIE PRZEKŁADNI GŁÓWNEJ 3.65G62 = MOCOWANIE NA 5 ŚRUBJL9 = ABSK13 = UŻYWANY Z FILTREM CZĄSTEK STAŁYCH UKŁADU WYDECHOWEGOK60 = ALTERNATOR,100AKCL = KANAŁ OGRZEWANIA,TYLNY PASAŻER 2-GA POZYCJALHD = KIEROWNICA PO LEWEJLPV = SILNIK WYSOKOPRĘŻNY Z17DTJ[LPV],A17DTJ[LPV]MM3 = UŻYWANY(-A,-E) Z RĘCZNĄ SKRZYNIĄ BIEGÓWMZ4 = M32 (WR) RĘCZNA SKRZYNIA BIEGÓWN34 = KIEROWNICA,TRZY SZPRYCHY,SKÓRA,ZESP.N65 = OPONA,ZAPASOWA,OSZCZĘDNOŚĆ MIEJSCANC0 = WYPOSAŻENIE,UNIA EUROPEJSKANS2 = DLA WSPOMAGANIA KIEROWNICY ZALEŻNEGO OD PRĘDKOŚCINT4 = EMISJA SPALIN,EEC 05NZX = KOŁPAK,KOŁAOHA = LOKALNY GM W EUROPE OHAQGF = OPONY,205/55 R 16-91HQN1 = KOŁO,JEZDNE,STALOWE,61/2JX16T96 = PRZEDNIE ŚWIATŁO PRZECIWMGIELNET9M = WYKOŃCZENIE ELBATM7 = AKUMULATOR,60AHTPV = KRATA WLOTU,CZARNA,Z CHROMOWANYM PASKIEMTR0 = OŚWIETL. WNĘTRZA,DACH,TYŁ,OSTRZEGAWCZE I PODWÓJNE DO CZYTANIATRP = RAMA RADIATSP = LAMPA USTAWIANA,ZESP.,OŚW. WNĘTRZATTXU07 = KLAKSON,FANFARAU3BU55U66 = GŁOŚNIKI,7U68 = KOMPUTER INFORMACYJNYUAC = TABLICA INFORMACYJNA WYŚWIETLACZA CIEKŁOKRYSTALICZNEGO - WIELOFUNKCYJNAUCH = RADIO AM/FM STEREO,SZUKANIE,CD,ETR,WYCISZANIE,MP3UJ3V2T = BAGAŻNIK PRZYCZEPNY,BAGAŻNIK,DACH,POWŁOKA PROSZKOWAV3D = BAGAŻNIK DACHOWY - BEZBARWNY DACH,CZARNYVG9 = WOSK ZABEZPIECZAJĄCYVJU = ŚRODEK TABLICY ROZDZ.,SATYNOWY KAMIEŃW1Y = DLA PRZYPADKU STEROWANIA RADIA NA KIEROWNICYW4YWBE = WYPOSAŻENIE JEDNOSTKI ODBIORNIKA,RADIOWFR = TKANINA WYKOŃCZENIOWA,TWIST/ELBAXA3 = OPELXK4 = DLA WŁOCHZ0H = DLA WŁOCHZ1F = PRĘDKOŚCIOMIERZ KM/H
Edytowane przez koles43
https://forum.opel24.com/topic/72789-pro%C5%9Bba-o-rozkodowanie-numeru-vin/page/50/#findComment-506278
Bardzo proszę o rozkodowanie VIN:WOLGM8EM3A1060801
Z góry dziękuję.
W0L:General Motors
G:Insignia
M8:M35 (Estate) (Elegance / Exclusiv)
E:Active (manual) Belts, driver & passenger front & front seat side, & roof side
M:A20DTH (LBS)
3:Cyfra Kontrolna
A:2010
1:Russelsheim
060801:SERIAL NUMBER
Numer silnika:17535697
Kod GM*Drive:TAEI
Data produkcji: 25.01.2010
REG: 54-KTL-8
01A = CZARNE WYKOŃCZENIE SIEDZENIA1AB = KOLOR WYKOŃCZENIA PŁATU DRZWI - CZARNY2A0 = WYPRASKA WEWNĘTRZNA DRZWI, ANTRACYT ZIARNISTY3A0 = WYKOŃCZENIE W KOLORZE CHŁODNY SZARY RAPID4AA = CZARNE WYKOŃCZENIE WNĘTRZA6X16Y4 = ZAPASOWE KOŁO I OPONA,USUNĄĆ7X18X29X2A14 = SZYBA,OKNO BOCZNE,TYLNE,ZABARWIONAA69 = NAPINACZ PASA BEZPIECZEŃSTWA, PRZEDNIA6B = DO SIEDZENIA Z CZĘŚCIOWO MANUALNĄ 6-KIERUNKOWĄ PROWADNICĄ USTAWIANIA SIEDZENIAA70 = BLOKADA, PAS BEZPIECZEŃSTWA Z NAPINACZEMAE4 = DLA SIEDZEŃ SPORTOWYCHAEF = ELEKTRYCZNE SZYBY, EKSPRESOWE OTWIERANIE/ZAMYKANIEAER = SZYBY STEROWANE ELEKTRYCZNIE,TYŁAFAAG5 = SIEDZENIE PRZEDNIE,PRAWE,REGULATOR WYSOKOŚCI,RĘCZNYAHS = ZAGŁÓWKI AKTYWNE 4-KIERUNKOWEAJT = DOTYCZY WARUNKÓW MONTAŻU SIATKI ZABEZPIECZAJĄCEJAPG = DOTYCZY PODPARCIA LĘDŹWIOWEGO STEROWANEGO ELEKTRYCZNIE W 4 KIERUNKACHATG = STEROWANIE ZAMKIEM W SYSTEMIE ZDALNEGO OTWIERANIA/ZAMYKANIAAXG = DOTYCZY SZYBY NA JEDNO DOTKNIĘCIEAXJAY0 = PODUSZKA POWIETRZNA,DACH,PRZÓDAY5 = ZAGŁOWEK,TYLNY,TKANINA,ŚRODKOWYB9K = OSŁONA PROGU DRZWIBAH = IMMOBILIZER,ELEKTRYCZNY,WARIANT 2BSO = IDENT.PUNKT EFEKTYWNY CON.C2B = OŚWIETL., WNĘTRZA, ZESP., PRZEDNIA PODŁOGAC59 = NAWIEW,TYLNA WENTYLACJA POWIETRZNAC68 = DLA KLIMATYZACJI ELEKTRONICZNEJC95 = ŚWIATŁO,SUFITOWE,ZESP.,Z PODWÓJNĄ LAMPKĄ DO CZYTANIAC99 = WYŁĄCZNIK PODUSZKI POWIETRZNEJ PASAŻERACE1 = WYCIERACZKA,PRZEDNIA,SYSTEM PRACY IMPULSOWEJCT5 = DLA HOLANDIID61 = SCHOWEK,STRONA KIEROWCYDA1 = PODŁOKIETNIK TYLNEGO SIEDZENIA,SCHOWEKDD8 = DLA LUSTERKA WEWNĘTRZNEGO CZUŁEGO NA ŚWIATŁODH6 = OSŁONA,PRZECIWSŁONECZNA,Z LUSTERKIEM OŚWIETLANYM,PRAWA-LEWADK6 = KONSOLA WEWNĘTRZNA SUFITOWADP6 = OBUDOWADT4 = POPIELNICZKA I ZAPALNICZKA (PAKIET DLA PALĄCYCH)DWE = UŻYWANE Z RĘCZNIE SKŁADANYM LUSTERKIEME94 = POKRYWAEA1 = SCHOWEK,OPARCIE SIEDZENIA PRZEDNIEGO,LEWA STRONAEA2 = SCHOWEK,OPARCIE SIEDZENIA PRZEDNIEGO,PRAWA STRONAEBZ = WYKOŃCZENIE PŁÓCIENNE SIEDZENIA, RIBBONF84 = PRZEŁOŻENIE PRZEKŁADNI GŁÓWNEJ 3.09FBD = BOCZEK DRZWI PŁÓCIENNY ATLANTISFX3 = PROGRAM STATECZNOŚCI ELEKTRONICZNEJGAR = LAKIER ZEWNĘTRZNY, PATRZ TABELA LAKIERÓW W PRZEDMOWIE KATALOGU MODELÓWGNA = WYPOSAŻENIE PODWOZIA, ZESPÓŁ PRZEDNIEGO WAHACZAGNC = WYPOSAŻENIE PODWOZIA, TYLNA OŚ, 4-ŁĄCZNIKOWEIK9 = ECOFLEXJ61 = DO STOSOWANIA Z 17" UKŁADEM HAMULCOWYMJ71 = ELEKTRYCZNY HAMULEC POSTOJOWYK13 = UŻYWANY Z FILTREM CZĄSTEK STAŁYCH UKŁADU WYDECHOWEGOK34 = STEROWANIE TEMPOMATUK3S = AKUMULATOR,75AHK60 = ALTERNATOR,100AKB5 = WSPOMAGANIE RUSZANIA NA POCHYŁOŚCIKC8 = GNIAZDO,WYJŚCIE MOCY DODATKOWEJKD4 = UŻYWANY Z GNIAZDEM ELEKTR. PRZEDNIEJ KONSOLIKI7 = GNIAZDO WYJŚCIOWE MOCY OSPRZĘTUKRHKRJ = DO WIELOFUNKCYJNEGO STEROWANIA RADIOODBIORNIKALBS = A20DTH[LBS] SILNIK WYSOKOPRĘŻNYLHD = KIEROWNICA PO LEWEJM53 = SPRZĘGŁO BLOKADY ZMIANY BIEGÓWMDE = DO RAMOWEJ WYPRASKI CHROMOWEJMM3 = UŻYWANY(-A,-E) Z RĘCZNĄ SKRZYNIĄ BIEGÓWMYJ = RĘCZNA SKRZYNIA BIEGÓW,6 BIEGOWA,TYPU F40N34 = KIEROWNICA,TRZY SZPRYCHY,SKÓRA,ZESP.N37 = KOLUMNA KIEROWNICZA, REGULOWANA, WYSUWANA I POCHYLANAN40 = WSPOMAGANIE MECHANIZMU KIEROWNICZEGO, NIEZMIENNY STOSUNEK WSPOMAGANIANC0 = WYPOSAŻENIE,UNIA EUROPEJSKANE9 = SYSTEM EMISJI EEC 09OHKPMA = UŻYWANE Z PRZEDŁUŻENIEM PODUSZKI SIEDZENIAPMB = UŻYWANE Z PRZEDŁUŻENIEM PODUSZKI SIEDZENIAQ02 = KOŁO 18X8,ALUMINIUM, 5 PODWÓJNYCH RAMIONQKD = OPONY WSZYSTKIE 245/45R18-96WT61 = DOTYCZY UKŁADU ŚWIATEŁ DZIENNYCH (DRL)T74T79 = DLA TYLNYCH ŚWIATEŁ PRZECIWMGIELNYCHT96 = PRZEDNIE ŚWIATŁO PRZECIWMGIELNET9T = 'ECOFLEX'TR0 = OŚWIETL. WNĘTRZA,DACH,TYŁ,OSTRZEGAWCZE I PODWÓJNE DO CZYTANIATR6 = POZIOMOWANIE REFLEKTORÓW,RĘCZNETSP = LAMPA USTAWIANA,ZESP.,OŚW. WNĘTRZATSQ = LAMPA WNĘTRZA DELUXETT4 = REFLEKTORY,HALOGENTTW = DO AUTOMATYKI ŚWIATEŁ GŁÓWNYCH Z CZUJNIKIEM JAZDY W TUNELUU18 = PRĘDKOŚCIOMIERZ,ZESP.,KM/GODZ.U65 = GŁOŚNIK,5UD5 = CZUJNIK,SYSTEM PILOTOWY POSTOJUUDC = DO CENTRALKI INFORMACYJNEJ KIEROWCY Z WYŚWIETLACZEM MONOCHROMATYCZNYM (MATRYCA PUNKTOWA)UDK = INFORMACJE GRAFICZNE - WYŚWIETLACZ KOLOROWYUH1 = OSTRZEŻENIE O ZAPIĘCIU PASÓW BEZPIECZEŃSTWA,PRAWA STRONAULS = STEROWANIE BLOKADĄ, KOLUMNA KIEROWNICZAUPH = Z INTERFEJSEM BEZPRZEWODOWYM,KRÓTKIM ZASIĘGIEM,ZAPISEM GŁOSUUS3 = RÓŻNORODNOŚĆ ANTENUSR = DO PORTU USBUXXV2T = BAGAŻNIK PRZYCZEPNY,BAGAŻNIK,DACH,POWŁOKA PROSZKOWAV3E = BAGAŻNIK DACHOWY - BEZBARWNY DACH,SREBRNYV83 = DEKLARACJA POJAZDU - ORGANIZACJA ECEVG2 = WOSK ZABEZPIECZAJĄCY,USUNĄĆVK8 = UCHWYT,OKULARYW1Y = DLA PRZYPADKU STEROWANIA RADIA NA KIEROWNICYW4YW5T = TABLICZKA SILNIKA,USUNIĘTAWGC = WYPOSAŻENIE JEDNOSTKI ODBIORNIKA,GPSWRAWRBWTR = TYMCZASOWA NAPRAWA OPONYXA3 = OPELXJ6 = DLA JAPONII (-2003) / DLA ZMODYFIKOWANEGO OBNIŻONEGO PODWOZIA (2009-)XL8 = DLA CZĘSTOTLIWOŚCI 433 MHZXQ5 = DLA HOLANDIIZ0G = DLA HOLANDII
https://forum.opel24.com/topic/72789-pro%C5%9Bba-o-rozkodowanie-numeru-vin/page/50/#findComment-506412
Witam,
proszę o rozkodowanie: W0L0XCF6846074596
Z góry bardzo dziękuję,
pozdrawiam
W0L:General Motors
X:Corsa
C:Corsa
F68:5 DRZWIOWY HATCHBACK
4:2004
6:Eisenach
074596:SERIAL NUMBER
Numer silnika:19CR7342
Kod GM*Drive:XXPV
Data produkcji: 22.01.2004
REG: BAR-PY 540
18I = WYKOŃCZENIE WNĘTRZA - CIEMNY WĘGIEL DRZEWNY18X = KOLOR WYKOŃCZENIA SIEDZENIA - CIEMNY WĘGIEL DRZEWNY18Y = WYKŁADZINA WYKOŃCZENIA DRZWI,W RÓŻNYCH KOLORACH20U = LAKIER ZEWNĘTRZNY, PATRZ TABELA LAKIERÓW W PRZEDMOWIE KATALOGU MODELÓWA32 = SZYBY STEROWANE ELEKTRYCZNIE,PRZÓDAG4 = SIEDZENIE PRZEDNIE,LEWE,REGULATOR WYSOKOŚCI,RĘCZNYAJ0 = ZAGŁÓWEK,TYLNY,TKANINA,DWAAJ7 = DLA KIEROWCY,PASAŻERA I BOCZNEJ PODUSZKI POWIETRZNEJAM9 = SIEDZENIE TYLNE,SKŁADANE DZIELONEAQ6 = SIEDZENIE PRZEDNIE,OPARCIE REGULOWANEAU0 = ZAMEK DRZWI,ZE ZDALNYM STEROWANIEMB76 = DLA PRZYRZĄDÓW Z CZARNYMI TARCZAMIB87 = Z CZARNĄ LISTWĄBF8 = SCHOWEK, PRZEDNIE SIEDZENIE, PRAWEC68 = DLA KLIMATYZACJI ELEKTRONICZNEJC79 = OŚWIETL. WNĘTRZA, SZYNA DACHOWA, OSTRZEGAWCZE I POJEDYNCZE DO CZYTANIAC87 = LAMPKA CZYTANIA MAPY,TYLNACT3 = DLA NIEMIECD75 = KLAMKA,ZESP.,ZEWNĘTRZNAD91DDU = LUSTERKO,ZESP.DJ9 = LUSTERKO,ELEKTRYCZNE I OGRZEWANE,SZEROKIE,NIEBARWIONE,PRAWE-LEWEE18 = KLAMKAEIS = WYPRODUKOWANO W EISENACHFY2 = PRZEŁOŻENIE KOŃCOWE PRZEKŁADNI GŁÓWNEJ 3.74G61 = MOCOWANIE NA 4 ŚRUBYJBF = DŹWIGNIA HAMULCA POSTOJOWEGO,MATOWA CHROMOWANAJM4 = SYSTEM HAMULCOWY,TARCZOWE-PRZEDNIE/BĘBNOWE-TYLNE,Z ABSK09 = ALTERNATOR,120AK12 = DLA FILTRA ZANIECZYCZEŃ WNĘTRZAKIR = NASADKA,GAŁKA DŹWIGNI ZM. BIEGÓW,SREBRNALHD = KIEROWNICA PO LEWEJLJ2 = Z14XEP[LJ2] SILNIK BENZYNOWYM24 = RĘCZNA SKRZYNIA BIEGÓW,5 BIEGOWA,TYPU F13, Z KRÓTKIM ZAKRESEM PRZEŁOŻEŃMM3 = UŻYWANY(-A,-E) Z RĘCZNĄ SKRZYNIĄ BIEGÓWN33 = DLA ODCHYLANEJ KOLUMNY KIEROWNICYN45 = KOŁO KIEROWNICY,TRZY SZPRYCHYNC0 = WYPOSAŻENIE,UNIA EUROPEJSKANT4 = EMISJA SPALIN,EEC 05NV8 = WSPOMAGANIE KIEROWNICY,ELEKTRYCZNIE STEROWANEOHA = LOKALNY GM W EUROPE OHAOIBPBP = WYKOŃCZENIE PIAZZA / ELBAPI5PW0 = KOŁO,JEZDNE,STALOWE,14 OTWORÓW,51/2JX14QQ5 = DLA KOŁA ZAPASOWEGO O PEŁNYCH WYMIARACHQWG = OPONY,175/65 R 14-82TT6C = PŁYTA WYKOŃCZENIA,WEWNĘTRZNA,STANDARDOWA,WARIANT 1T74TN6 = AKUMULATOR,55AHU33 = ZAPALNICZKA,USUNĄĆU91 = ANTENA KRÓTKA,DACH,RADIOUJ3UN5 = RADIO,CAR 2003UW6 = GŁOŚNIK,6VK8 = UCHWYT,OKULARYVU3 = ŚRODEK TABLICY ROZDZ.,WĘGIEL DRZEWNY METALICZNYW2N = LITERNICTWO,BOCZNE,USUNĄĆW2Y = POKRYCIE,PŁASKIE,KOŁO,WARIANT 4W4YW8X = CZĘŚCI DODATKOWE,INSTALACJA RADIAXA3 = OPELXG3 = DLA NIEMIECXL8 = DLA CZĘSTOTLIWOŚCI 433 MHZXM5 = WYPOSAŻENIE,POZIOM 1Z0F = DLA NIEMIECZ1F = PRĘDKOŚCIOMIERZ KM/HZ1Y = FARBA,DWA POKRYCIA
https://forum.opel24.com/topic/72789-pro%C5%9Bba-o-rozkodowanie-numeru-vin/page/50/#findComment-506443
Witam,
Prosiłbym o rozkodowanie W0L0XCF0643013895.
Z góry dziekuję i pozdrawiam.
Edytowane przez gregoryk
https://forum.opel24.com/topic/72789-pro%C5%9Bba-o-rozkodowanie-numeru-vin/page/50/#findComment-506622
Witam
prosze o rozkodowanie nr VIN
W0L0ZCF4831122013
hajdzik@onet.eu
W0L:General Motors
Z:Vectra
C:Signum
F48:5 DRZWIOWY HATCHBACK
3:2003
1:Rüsselsheim
122013:SERIAL NUMBER
Numer silnika:11198357
Kod GM*Drive:XXLQ
Data produkcji: 25.04.2003
REG: AN-E 62
2J84BU = LAKIER ZEWNĘTRZNY, PATRZ TABELA LAKIERÓW W PRZEDMOWIE KATALOGU MODELÓW80I = WNĘTRZE-CZARNY80X = WYKOŃCZENIE WNĘTRZA NADWOZIA-CZARNY80Y = WYKOŃCZENIE PŁATU DRZWI,CZARNYA33 = SZYBY STEROWANE ELEKTRYCZNIE,TYŁA51 = PRZEDNIE SIEDZENIE KUBEŁKOWEA53 = SIEDZENIE PRZEDNIE,PASAŻERA,6-FUNKCYJNA OBSŁ. RĘCZNAAH4 = FOTEL PRZEDNI,KIEROWCY,RĘCZNY SZEŚCIODROŻNYAHA = Z REGULACJĄ PODPARCIA LĘDŹWIOWEGOAHB = Z REGULACJĄ PODPARCIA LĘDŹWIOWEGOAP9 = SIATKA PRZEDZIAŁU ŁADUNKOWEGOAY0 = PODUSZKA POWIETRZNA,DACH,PRZÓDBA9 = POJEMNIK ZIMNABD8 = WYPRASKA,ZESPÓŁ,DACH,W KOLORZE NADWOZIABDT = WYPRASKA WEWNĘTRZNA,GRANDBW4 = Z WYPRASKĄ CHROMOWĄC77 = WENTYLATOR,POWIETRZE WYMUSZONEC95 = ŚWIATŁO,SUFITOWE,ZESP.,Z PODWÓJNĄ LAMPKĄ DO CZYTANIACE1 = WYCIERACZKA,PRZEDNIA,SYSTEM PRACY IMPULSOWEJCE4 = SPRYSKIWACZ REFLEKTORACJ2 = STEROWANIE KLIMATYZACJICT3 = DLA NIEMIECD09 = PODŁOKIETNIK,PRZEDNI,ŚRODKOWYD75 = KLAMKA,ZESP.,ZEWNĘTRZNAD7J = PŁASKIE OPARCIE SIEDZENIA,SKŁADANE,PRAWEDD8 = DLA LUSTERKA WEWNĘTRZNEGO CZUŁEGO NA ŚWIATŁODDG = LUSTERKO,ELEKTRYCZNE,PRAWE-LEWEDH6 = OSŁONA,PRZECIWSŁONECZNA,Z LUSTERKIEM OŚWIETLANYM,PRAWA-LEWADT4 = POPIELNICZKA I ZAPALNICZKA (PAKIET DLA PALĄCYCH)DV8 = PRZYRZĄDY,CZARNY,CZARNE PIERŚCIENIE,SREBRNY,CHROPOWATEEA1 = SCHOWEK,OPARCIE SIEDZENIA PRZEDNIEGO,LEWA STRONAEA2 = SCHOWEK,OPARCIE SIEDZENIA PRZEDNIEGO,PRAWA STRONAFR8 = PRZEŁOŻENIE PRZEKŁADNI GŁÓWNEJ 4.17 (FRT)FX3 = PROGRAM STATECZNOŚCI ELEKTRONICZNEJG67 = URZĄDZENIE AUTOMATYCZNEGO SAMOPOZIOMOWANIAJL9 = ABSK09 = ALTERNATOR,120AK34 = STEROWANIE TEMPOMATULCH = SILNIK BENZYNOWY Z22YH[LCH]LHD = KIEROWNICA PO LEWEJMG3 = RĘCZNA SKRZYNIA BIEGÓW,5 BIEGOWA,TYPU F23MM3 = UŻYWANY(-A,-E) Z RĘCZNĄ SKRZYNIĄ BIEGÓWN65 = OPONA,ZAPASOWA,OSZCZĘDNOŚĆ MIEJSCANC0 = WYPOSAŻENIE,UNIA EUROPEJSKANR0 = ZESPÓŁ KOŁA KIEROWNICY,Z CZTEREMA RAMIONAMI,SKÓRANT4 = EMISJA SPALIN,EEC 05NW9 = STEROWANIE TRAKCJIOHCQD1 = KOŁO,JEZDNE,ALUMINIUM,61/2JX16QFP = OPONY,215/55 R 16 93VR2DRUE = WYPRODUKOWANO W RUESSELSHEIMSVB = UCHWYT NA NAPOJE, TYLNYT6C = PŁYTA WYKOŃCZENIA,WEWNĘTRZNA,STANDARDOWA,WARIANT 1T96 = PRZEDNIE ŚWIATŁO PRZECIWMGIELNETN7 = AKUMULATOR,66AHTR0 = OŚWIETL. WNĘTRZA,DACH,TYŁ,OSTRZEGAWCZE I PODWÓJNE DO CZYTANIATR7 = POZIOMOWANIE REFLEKTORÓW,AUTOMATYCZNETT6 = REFLEKTORY,KSENONU08 = UŻYWANY(-A,-E) Z KLAKSONEM WIELOTONALNYMU3AU55U68 = KOMPUTER INFORMACYJNYU88 = GŁOŚNIKI,9U91 = ANTENA KRÓTKA,DACH,RADIOUD5 = CZUJNIK,SYSTEM PILOTOWY POSTOJUUE2 = SYSTEM NAWIGACYJNYUEC = WSKAŹNIK CZUJNIKA AUTOMATYCZNEJ RECYRKULACJI POWIETRZAUF5UJ3UR7 = RADIO AM/FM STEREO,SZUKANIE,MULTI CD,ETR,TELEFON,NAWIGACJA,WYCISZANIEUV9 = WYŚWIETLACZ,SYSTEM NAWIGACYJNYV2T = BAGAŻNIK PRZYCZEPNY,BAGAŻNIK,DACH,POWŁOKA PROSZKOWAVY7 = DŹWIGNIA ZMIANY BIEGÓW,SKÓRAW1Y = DLA PRZYPADKU STEROWANIA RADIA NA KIEROWNICYW2N = LITERNICTWO,BOCZNE,USUNĄĆW4YW8E = RADIO,201-T ©W9M = DLA DODATKOWEGO ONSTAR'U LUB CZĘŚCI SYSTEMU NAWIGACYJNEGOWD4 = IDENT.PUNKT EFEKTYWNY CON.XA3 = OPELXA7 = OGRZEWANA DYSZA SPRYSKIWACZA SZYBY PRZEDNIEJXG3 = DLA NIEMIECY67 = WYMAGANE,GDY ZAMONTOWANO WYŚWIETLACZ POZOSTAŁYCH USŁUGZ0F = DLA NIEMIECZ0L = ELEGANCEZ1F = PRĘDKOŚCIOMIERZ KM/HZ1Y = FARBA,DWA POKRYCIA
https://forum.opel24.com/topic/72789-pro%C5%9Bba-o-rozkodowanie-numeru-vin/page/50/#findComment-506723
